i have a 84 gt i just put my 87 5.0 motor in it because i spun a bearing(84motor) , now it doesn't crank over by turning the ignition key so i tryed to start it by putting a screw driver across the silniod and it cranks but there is no spark at all, so i thought my ignition box was bad so i got it tested and it was still good so what do i do???
yeah it does have 12v because my fuel pump is working and it runs off of there
I think you are misunderstanding where I'm telling you to test. your fuel pump takes it's power off the always hot side of the selonoid, I'm telling you to test the small wire that triggers the selonoid that comes from the ignition switch which is only hot in crank.
