Any1 ever heard of this? I havent
I have a mind-boggling problem, at least to me it is. I was on the way back from the gas station yesterday after filling my tank. Car was driving fine until I hit a huge freakin pothole with my rear wheels. The car stalled out i cranked it back up, a few secs later i hit a bump in the road and again it stalls out. Now it will crank up fine usually but as soon as I make a rolling tuen it stalls out. Basically any movement of the car and it shuts off. I can sit inside, imma a big guy and rock the car and it will shut off.
WHat can this be I really dont know where to start. I checked a few things but none of that is the problem. Could the inertia switch have gone bad. The car has a new walbro 255lph in the tank so i doubt its the pump.
I have pushed the reset on the switch. I just have to check the wiring on the pump.
I doubt it's the inertia switch...first you need to find out if it's stalling due to loss of spark or fuel, sounds like you have a bad or loose connection somewhere, hooking a fuel pressure gauge up and performing what is known as the ford "wiggle" test by going around and lightly tugging on all harness connections in relationship to the fuel system or ignition system will help locate such a problem
dude had the same thing happen to me a couple years ago....turned out when i hit bumps my ignition switch in my steering column was so worn out it was loose and it would actually turn the key back a hair,so little i never seen it visually, not saying thats your prob. but check it out.
KingRando
10-01-2015 11:16 AM
