Is my clutch/trans going to explode???
I go to start my car today, just like any other day. Put the stick in neutral, press the clutch in, and turn the key. Immediately after starting I heard a loud spinning whirring sound (like something was spinning freely) coming from somewhere between the shifter and the engine. I immediately turned off the engine, but the whirring/spinning continued for about 5 seconds before the engine sounded like it was trying to turn over again. Not knowing what else to do, I put the gear in 1st and let off the clutch to stop it from turning, and it worked.
WTF is happening here?
On a related side note, before this strange occurrance, I've been having issues with starting the car once in a while. I'll turn the key, the engine starts to turn, then I hear a loud click/knock followed by a whizzing sound and thud (car does not start). On the next start it starts fine. This happens like once a month.
Anyone have any idea what's going on???
Thanks.
1990 GT, stock motor, rebuilt trans, centerforce I clutch, FMS clutch cable, and FMS Aluminum clutch quadrant.
Thanks.
throwout bearing is the most likely cause of the noise. as far as the click/knock during start, i'd have to be there to make a positive diagnosis, but i'd check teeth on the flywheel while your doing the bearing.
a year or 2 ago I had a problem while city driving in stop and go traffic. This was a new clutch BTW....All of a sudden it wouldn't get into gear, then once in gear...the car wouldn't go even when giving it gas. It was definately in gear, but I heard a rattling sound as if something was spinning loosely. I turn it off and try again and somehow it went away.
At the time I've it checked out several times, shop found nothing. They said they "readjusted" the clutch and it seemed to be ok. had more problems down the road, so they swapped out the new clutch cable for another FMS self adjusting cable. Still wasn't right, the next day after work, I went to start it...it made that clunk sound, whizzing sound, and the clutch pedal just dropped to the floor and the car didn't start. The clutch pedal was limp. I pulled up on it and pressed it all the way in and it reconnected. Took it to the shop. They replaced the Quadrant with a Ford Aluminum one. The clutch pedal effort was noticably easier. shifted great. That worked for a while, but the shifting problems continued.
The mechanic looked at it again and said the screw at the end (i think) of the clutch cable could be slipping out, so he put loctite on it to keep it put.
And here I am today.
Another thing I'm wondering that may be connected somehow......lets say im in 2nd gear and accelerate, then let off the gas completely. With the sudden deceleration, i'll hear a loud knock that sounds like it's under my seat. maybe it's the gears slappin, i don't know.
I'm just trying to give all the information i have hoping it may help shed some light on what's really going on.
I've just about had it with this crap.
benstangs
02-15-2006 03:39 PM
