Drivability problems at low slow speeds
After checking the search and comimg up empty I put this out there... when driving my 88 5.0 5 speed through a parking lot with my foot off the gas, how come the car...for lack of a better description...goes lug lug lug lug? As if it is belt driven and there is alot of slack in the belt.
you can't let the car push it's self along without giving it some gas.....now if the car does it / surges when you give it light throttle pressure then make sure your maf is clean and no vaccum leaks exist
No maf on my 88 but vaccum leaks are always a possibility. So what you are saying is this is common on 5spd cars.
not to sure exactly what you are feeling, it's one of those things that sitting in the seat and going for a ride and have you explain the prob would make diagnosis alot easier
Check for vacuum leaks, because that will make it worse. I had that one happen to me. When I need to drive slowly in a parking lot or something, I always let the car glide in neutral, then give it a little gas in first to help it along.
Haha, Anyways, your description was actually quite good as what you are describing is called lugging an engine, which honestly, should never be done as it is EXTREMELY hard on the engine, it's hard on near every component in the engine, from bearings (thrust bearings especially), to cylinders. When I pull an engine apart I can tell you exactly how the engine was driven, how often it idled, if the customer rode the clutch, or if it was lugged, just by looking at simple components, thrust bearings tell a good story generally.
Lugging an engine is essentially working an engine harder than you are allowing it. If you shift early into 5th, and it's revving a grand and your foot is to the floor trying to get the rpms up, that's lugging an engine as well. This is not a characteristic of a Mustang, every vehicle with a standard will do this, except diesels, to a point, diesels make enough torque they are near impossible to lug unless they are towing.
