302 setup question
302 setup question
Hey guys looking for a little help on a car im looking at.Here is what the guy says it has in it.Questions are how much power should it be making.He said the set up was fresh and hadn't got it tuned or dynoed or taken to the track.He only wanted $2800 thought I would ask people who knew alot before I really thought about it.Thanks guys and God bless
1982 capri
Motorsport 302 crate motor
351 Windsor heads (matched and ported, 2.02" valves)
Motorsport f303 billet roller cam
Motorsport roller lifters
crane roller rocker arms and pushrods
Victor Jr. single plane intake
Hooker full length slip in headers
Holley 650 4bbl carb.
Converted to serpentine belt drive system
Msd Ignition box
409 Racing Wires
Mallory Distributor
Monster Tach
MainBattery Disconnect
Built C6 transmission
2800 stall converter
B&M Starshifter
6pt roll cage
subframe connectors
traction bars (not currently installed but come with vehicle)
rear coil over drag shocks
Line lock brake system
racing seats
5 pt racing harness
10 gallon fuel cell
Steel 1/2 fuel line from front to back
Battery mounted over right rear tire using 00 cable
Duel Holley fuel pump and gauge set-up (for future NOS use)
Dyna mat under carpet for heat and sound
1982 capri
Msd Ignition box
409 Racing Wires
Mallory Distributor
Monster Tach
B&M Starshifter
6pt roll cage
subframe connectors
racing seats
5 pt racing harness
10 gallon fuel cell
Thats sounds like a great deal. No matter what the body is like. If the motor is still in good shape it will run for years and years. My guesstimate fr HP#s would be around 350 at the fly wheel which is damn good. Go for it man.
Why are you still here, and not out buying the car? Make sure the guy is not BSing you. Look under the hood, and verify to the best of your ability what he is saying it has is true. Have him point the stuff out. Drive it and make sure it runs well and pulls hard, and go for it.
Galactic
04-29-2019 02:56 PM
uberstang1
09-20-2015 06:42 PM
jaiidutch
09-14-2015 10:29 AM
