? Kenne Bell Blowzilla
Sounds good. I have even heard roomers that the addition of a supercharger in a 5 liter mustang can even help mileage. Is there any truth in this?
+1 to all of Samseed's points. Also, when not in boost your car will feel more torquier than a regular NA. That is because the SC is forcing in more air all the time. This does not result in gas mileage loss. By adding my Vortech to my car, my mpg dropped .3, so it's not to bad of a tradeoff.
Bottom line: If you're worried about gas mileage a blower is not a good idea, neither is a Mustang for that matter.
Well the idea behind that is the engine does not have to work at sucking in air thus making it more efficient. On the other hand the engine has to work to turn the blower so that could just cancel it right out.
Absolutely. Did you know that due to the fine-tuned allignment of the rear suspension of the Mustang, it is better for the car to slide sideways around all corners under full throttle? Neither did my wife, until I showed her! LOL!
Ought to and reality are two seperate things...Once I fix my h20 pump, which was a bitch involving maap and a mallet resulting in a melted water pump and broken timing cover, since gas is so cheep ill make sure to fool arround. Hell, those 3.73s are gonna give more incentive to do just that.
