not even 600 miles and....
Old 11-09-2008, 11:37 AM
jssblues
jssblues's Avatar
Question not even 600 miles and....
i already have this loud tapping noise that at first was only here and there, you would hear it at idle rev it up and it would go away, now it is just constant....i just cant tell if it is coming from the top or bottom
jssblues is offline
Old 11-09-2008, 12:15 PM
saleenpride1986
saleenpride1986's Avatar
Is it a tapping noise like rocker arm tapping or is it like, a loud metal on metal noise?
saleenpride1986 is offline
Old 11-09-2008, 12:16 PM
saleenpride1986
Also, you said 600 miles. I'm assuming it's a new engine since your sig says fresh 306???
Old 11-09-2008, 12:19 PM
DriftingRz
DriftingRz's Avatar
if i was you. id pull valve covers off and check just to be sure. my buddy with a 68mustang (331 stroker) had a lil tapping noise. and his rocker actually came off while romping on it a week or 2 ago. it doesnt take long to pull off the valvecovers. so id check just to be sure. and if its a fresh 306. you may want to retorque it all down again anways.
DriftingRz is offline
Old 11-09-2008, 01:00 PM
jssblues
jssblues's Avatar
it is a rocker arm tapping sound but i already pulled the valve covers and re-torqued them and it has all but gotten worse
jssblues is offline
Old 11-09-2008, 02:16 PM
saleenpride1986
Did it get worse immediately after you re-torqued? Or did it gradually get worse again like the original slow to worse to worst noises? If it instantly became 10x worse after you re-torqued perhaps it is the rockers even though you just re torqued.
Old 11-09-2008, 06:33 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
post a video of the noise, but you need to check the valve adjustment by making sure each adjustment is set or checked while the lifter is on the base circle of the cam while checking each valve
mjr46 is offline
Old 11-09-2008, 06:45 PM
crusin92red5.0
crusin92red5.0's Avatar
WHat mjr, you move up to a Mod? WHen did this happen?
crusin92red5.0 is offline
Old 11-09-2008, 06:47 PM
w8less
w8less's Avatar
today
w8less is offline
Old 11-09-2008, 09:02 PM
saleenpride1986
I noticed that too!
Galactic
04-29-2019 02:56 PM
heslekrants
09-23-2015 04:02 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: not even 600 miles and....
