Flushing the block
Flushing the block
hey guys, i got another question
how might i go about flushing the coolant out of the block, its still orange?
should i just drain the read, undo the lower hose and spin the water pump?
the flush kit will flush all the crap out, once water comes out clear...then shut car off, hook all hoses back up then drain radiator and fill radiator back up with straight coolant since pure water is in the block and then cycle / bleed cooling system, once two mix there will be a complete mixture 50/50 in the cooling system
Good point Fuzzydice but the water is to flush and carry out all the particles, dirt, flakes of rust etc.
Drain out the water. Problem is alot of water remains in the block. You can then fill the system up with distilled water. It's less than $1 a gallon. Fill and drain. Repeat if you can handle the $$.
Now look up your cooling system's capacity. If it's 16 quarts. Make sure to pour at least half of that. If it drank the 8 quarts and it's still down. Top off with distilled water.
