1979 Mercury Capri coolant plug
Old 11-12-2008, 02:16 PM
computergeek1337
computergeek1337's Avatar
Default 1979 Mercury Capri coolant plug
Hi, I have a 1979 Mercury Capri, and I want to replace the coolant. However, I can not find the radiator drain plug. I looked under the radiator, and I still can't find it.
Question: Where is the radiator/coolant drain plug on a 1979 Mercury Capri? (Please be a specific as possible)
computergeek1337 is offline
Old 11-12-2008, 02:24 PM
redpony88
redpony88's Avatar
if it's in the same spot as the mustang which it should be... looking at the motor it should be on the bottom left. try leaning over the front and looking down it's on the side, not the exact bottom
redpony88 is offline
Old 11-12-2008, 02:32 PM
computergeek1337
http://www.google.com/products?q=197...num=1&ct=title
does it kinda look like that? Cause if so I found it, and thanks.
Old 11-12-2008, 03:58 PM
mattdel
mattdel's Avatar
yup. probably gonna need a pair of pliers to crack it open but be careful not to twist it, they snap ez
mattdel is offline
Old 11-12-2008, 07:29 PM
computergeek1337
Got it! Thanks a bunch!
BOB ROME
07-26-2023 01:54 PM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: 1979 Mercury Capri coolant plug
