Yeah...it is only 5mm. I just always see the MAF being the larger of the two. This is how the car came when I got it. If it's worth spending the money for a new one I will. I don't care about the cost. Thanks for the help.
If the system (MAF, air pipe and ECM) are calibrated to work with the injectors you have set, the 80mm TB will not affect the MAF. Lets say the 80mm flows more than the intake setup..... what will be the bottleneck? ......the MAF? The sensor will continue to work under its transfer curve and measure the g/s of air going through it as usual......... simply b/c the TB is a regulating valve now, if you monitor its signal, and see it is pegged (maxed out) @WOT..... time for a new MAF.
