Throw Out Bearing?
I have replaced 3 TOB's in the past year, getting ready to replace another. Tried Ford, Center Force, Advance Auto. Contacted D&D and decided to try one of theirs and change out bearing retainer on transmission with the steel one, a new pilot brng and new clutch fork. Also replacing clutch quadrant, cable and firewall adjuster from Steeda. I'm staying with the same clutch though. Center Force Dual Friction. Damn good clutch.
Its not you throw out bearing. If you had your clutch pedal in and it made the noise it would be your throw out bearing. If it is making noise when your foot is not on the clutch it is your PILOT bearing. Although when changing either you should change both because all is apart. and if your getting it done vs. doing it your self then they will probably both be replaced anyways.
This sounds almost exactly what mine was doing.
https://mustangforums.com/forum/5-0l-1979-1995-mustang/477751-squeaking-when-clutch-disengaged.html
KingRando
10-02-2015 08:06 AM
Offendant
09-23-2015 07:21 PM
