Will these pistons work for my setup?
Gonna run gt40p heads and intakes and a tfs stage one cam. Looking to bump up compression.
http://cgi.ebay.com/ebaymotors/Ford-...Q5fAccessories
Well i can't afford a full stroker kit, dont feel like messin with the juice. I just want a solid 5.0. Mind you i already have two cars that are fast enough. But would having it bored .30 over be somethin that i need to do in order to get some compression. My buddy said some flat tops that'll get me to 10:1 would be good enough. But i dont know which pistons to get that will do that.
what you need is
Sealed Power #844-L2488F30
1985-87 5.0L HO Stock-Type Piston, .030'' Overbore
Piston Dia.: 4.030''
Piston Top: Flat Top, 4-Valve Reliefs
Pressed Pin
Comp Ratio: 10.14:1 w/54.5cc Heads, 8.89:1 w/69cc Heads
Ring Grooves: 1.5mm, 1.5mm, 4.0mm
Sold as Each
More Details
$44.99
Ships
in 7-8 weeks
Pressed Pin
Sold as Each
More Details
$44.99
Ships
in 7-8 weeks
jegs or summit is a good place to look around . most there pistons are listed with comp. ratio with certain cc heads
http://shop.enginekits.com/osb/specials.cfm
try here too
try here too
