Exhaust, Intake
Exhaust, Intake
just got my full exhaust set up, JBL shorty jet coated headers, magnaflow x pipe and cats, cat back, dual 2 chamber flowmasters, 3" tips. now that i got the output i wanna do the input, intake. was thinkin cobra. or should i go like trick flow. suggestions?
Are you looking for just an intake or are you going to swap out the heads too? How about the camshaft? If you're going to take out the intake and swap it, you might as well do the other two as well. It can be a bit pricey, but if you shop around there are good deals to be had.
Doing a full H/C/I is going to be your best bet. However, installing just an intake manifold is a pretty easy project to do. When people ask to just install a cam, then doing the H/C/I at once is the best thing to do. I would get the cobra intake. It flows well for a mild H/C/I car or bolton. If you are on a budget, you could also get the explorer manifold from a local junkyard. It is identical to the cobra.
Luke9222
10-22-2015 11:55 PM
09-10-2015 08:39 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
