EGR Vaccum
Old 11-21-2008, 10:43 AM
rockarmymedic
rockarmymedic's Avatar
Default EGR Vaccum
Where should I get Vacc from for the hook up on the EGR? I though off of the tree on the back of the upper intake but that caused the EGR to go wide open at idle. Any pics or Diagrams would be great.
rockarmymedic is offline
Old 11-21-2008, 12:38 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
It comes from the egr solenoid. Not from a direct port. That's what causes the egr to be open at idle when it shouldn't be.
The Electronic Exhaust Gas Recirculation (EEGR) system is controlled by the Electronic Control Assembly (ECA) , based on return signals from various engine components. The EEGR system utilizes a valve position sensor, and a solenoid-type vacuum regulator device. Circuit power is supplied through the ECA power relay, and circuit ground is provided internally by the ECA.
The EGR Valve Position (EVP) Sensor informs the ECA of the EGR valve's position through a voltage return signal. This signal is directly proportional to the amount of exhaust gas being recirculated. The EGR Vacuum Regulator (EVR) controls the vacuum applied to the EGR valve diaphragm.
NOTE: Other Vacuum Related Components may be incorporated into the EEGR system, depending on vehicle model and Calibration.
PRO50SC is offline
Old 11-21-2008, 07:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
from manifold to selonoid then from selonoid to egr as pro50sc states
mjr46 is offline
LivingInThePast
09-16-2015 12:20 PM
TfcCDR
09-14-2015 12:08 PM
J.casone400
09-03-2015 04:43 PM
J.casone400
08-25-2015 12:19 PM
SANDY21
08-17-2015 02:41 PM
Quick Reply: EGR Vaccum
