retorquing lower intake after running engine
i had to retorque mine because after my spring install i put the whole top end back together. i ran it for a week and the back of my instake leaking. i just decided to check the bolts just in case, they are finger tight. i retorqued and havent had a leak since. i still run iron E7's for now.
maybe just a freak incident but i had to retorque mine down cause of a leak. hasnt since.
edit: i did use the chilton for the TQ specs and sequence, went half the TQ recommendation first sequence then recommended TQ specs second sequence and went through a third time just to make sure. still had my leak until i retorqued the sequence once more.
This is perfect. When I first read about this re-torquing stuff i was like they can't possibly re-torque everything before selling the vehicles. That's just ridiculous.
I did that when I built my engine. Just went back and "snugged" them a few times with time inbetween snugs...in the right order yet though...never retorqued either.
Is it what you're threading or threading into? 25 is high for explorer LIM torque
Gary Ugarek
09-05-2015 09:03 PM
inyadreems
08-21-2015 09:10 AM
