ok so i changed my brake booster, master cylinder, calipers, pads, and bled them....and the pedal feels hard, really hard dont know if its cus the new booster or what. but it just does not feel right. does anyone have an idea
Wouldn't be the first bad booster I've seen. With the engine running pull the check valve out of the booster and make sure you have a good Vac signal. Next thing is do you have any brake pedal travel or is it hung up at the top with the brakes locked. Some have a adjustable plunger that isn't adjusted and will hang the pedal at the top. See if the wheels will turn after yet release the pedal.
