Starting the one wheel burn
My 87 is starting to only spin one wheel, so I'm guessing the trac-lock is done.
Any ideas on what I should replace it with keeping in mind Im on a budjet. I was looking at this. http://www.latemodelrestoration.com/...0%201&comp=LRS
My next question is: How hard are they to replace?
if you're on a budget then why not this one here? this is what i'm running in my 83. (i swapped out the 7.5 with an 8.8)
they arent Bad since you arent changing gears or anything it should be pretty straight forward
i don't even think you'd need that. just get a rebuild kit with the cf clutches and you'll be set. or if you want to upgrade axles to 31 splines, you could either get an aftermarket diff like the one you linked us or be like me, save money and just get an explorer 8.8 tlok
you pull the cover, then pull the axels if you've never done it before, pull the bolt that holds the dowel in the center then pull the dowel, after that the axels are able to slide in slightly and you can pull the c clips off. then they slide out. pull the 4 bolts holding the diff in and pull the ring gear off
So once you get the ring gear out, you can get to the trac lock unit. I've never messed with the rear gears so I don't want to f it up.
I have pull the axles before just haven't messed with the gears.
I bought this one
http://www.blueovalindustries.com/pr...p?pid=99012821
And you can get these
http://www.blueovalindustries.com/pr...p?pid=99012822
and spend less than that locker
I bought this one
