5.0 Questions...
5.0 Questions...
it's a screamer, but it took a lot to get it there!!
MODS:
BORE 40 OVER, the block cam and crank are balenced @ a 306
windsor jr stage 3 pushed dart heads
edlebroc performer upper & lower intake
trw high compresion pistons
eagle conecting rods
1.7 roller rocker arms
comp. pushrods
roller lifters
e303 cam
24 lb injectors
190 lph fuel pump
steel foged crank
ceterfoce 30lb lightened flywheel
king cobra clutch
bbk cold air kit
70mm throttle body
75mm mass air w/ upgraded sensor
stage 3 cpu system
then auto meter pod guages and a tach
i'd list the suspension mods but it would take a while
MODS:
comp. pushrods
roller lifters
e303 cam
24 lb injectors
190 lph fuel pump
steel foged crank
king cobra clutch
bbk cold air kit
70mm throttle body
stage 3 cpu system
