whos got the info on MAFs and tuning? - Page 2 - MustangForums.com
Old 11-29-2008, 11:48 PM   #11
dudeboy
Definately use the sensor AND the housing from the 94-95 Mustang.
They can be found on other cars as well... I've pulled a couple from 4.6L cars...
This MAF housing actually bolts to the intake, as opposed to the Fox housing which slips into the intake tubing.
You can find the adapters on ebay most the time. It is a 4-bolt flange adapter for a 70mm MAF.
The sensor part number will start with 'F2VF-******'
Any other sensor in the 70mm housing and it won't work with the Fox ecu's.
The 94-95 Mustang MAF can only be used on Fox Mustangs when 19Lb injectors are still being used.
dudeboy is offline   Reply With Quote
Old 11-29-2008, 11:49 PM   #12
dudeboy
Quote:
Originally Posted by TexasHotrod View Post
That will work with the stock injectors no tune??
Correct... stock injectors, and NO tune....
Old 11-30-2008, 10:44 AM   #13
zippo2341
zippo2341's Avatar
do subframe connectors make a difference? i do drive this car daily to collage and work so will affect comfort at all? idk if it will make a difference or not but the body has currentlly at 86,xxx.
zippo2341 is offline   Reply With Quote
Old 11-30-2008, 08:37 PM   #14
FoxGT
FoxGT's Avatar
You want the air meter you're putting on to have as close to the stock resistance for the same airflow. For example; 2.5volts to the stock computer is about 90cfm, so ideally you want another air meter that at about 90cfm is sending the same signal to the eec, around 2.5v. If the voltage is off, depending on which way it's off will make your car run richer or leaner.
& for the record 356cfm is a huge difference, that is about the equivalence of 235-245whp difference.
FoxGT is offline   Reply With Quote
Old 11-30-2008, 09:39 PM   #15
dudeboy
Quote:
I wouldn't suggest sizing a MAF meter this way.... The output from the MAF is not linear, and there is no guarantee that the curve rates will be the same.
In other words...
2 different meters may 'match up' at 2.5v, but be WAY off by 3.5v....
You would need to evaluate the entire MAF output curve.
Old 12-01-2008, 09:17 AM   #16
FoxGT
FoxGT's Avatar
Quote:
In other words...
Of course not. I was just using 2.5v as an example. I agree.
Old 12-01-2008, 10:44 AM   #17
Project 5.GO!
Project 5.GO!'s Avatar
Quote:
Hey, collage is a form of art. College however, is an institution of higher learning... ***
***Disclaimer:
I'm just messing with you, and not trying to be a dick! LOL!
Project 5.GO! is offline   Reply With Quote
Old 12-06-2008, 06:13 PM   #18
zippo2341
zippo2341's Avatar
i always new i should have gotten "hooked on phonics'
Legendary Hurst shifters - up to $50 rebate carid General Tech 1 07-08-2016 09:55 AM
When would you tune? firecoyote The New S550 2015-2017 Mustang 28 09-27-2015 02:37 PM
First Impression 2015Ecoboost New Member Area 3 09-17-2015 01:48 PM
Noob needs help! 86 mustang svo motor swapped to 71 5_speed carb 302 v8 jaiidutch Motor Swap Section 2 09-14-2015 10:29 AM
AM or Bama please comment whatsup62 5.0L GT S550 Tech 1 09-03-2015 01:38 PM
Featured Sponsors
