throttlebody help
i cant explain it any better,the rod attaches to the part that has the ball on the end that hooks to the cable,the rod runs through the t/b up to the tps,it has the blade on it,where the rod hooks to the plate that has the ball end on it,it looks like its pressed on it,it has slack in it,i can unhook the cable and it still moves,it has nothing to do with the cable,it is the plate that has the ball on it,right under the spring on the trottle body,the throttle body is a maybe a year or 2 old,the rod and that plate arent one piece,it is either pressed on or it was welded,and mine is loose.
I know what your talking about but apparently im not typing what you want to see...And every tb i've ever seen that shaft has been one piece..IMHO If it was my **** it would already been in the trash and a new one on order.But just take it apart and super glue,jb weld,silicone the **** out of it..I give up..
its not the shaft its where the shaft and the plate at the bottom meet.its not one piece,it has to be either welded or pressed on.the stock one the part im talkin about the shaft is welded to that plate.
Dude are you serious????The damn thing would be one piece if it was welded.And hell from the post you've been making you have already anwsered your own question.Have you ever torn down a TB by any chance?
well on my bbk it isnt welded it never was welded
I see you changed your post before i could report....LMFAO..I will make sure not to waste my time anymore..And i'll get my girl to do that for me so please a nice day...
ur the dumbass tellin someone to drill there ****in bleeder screw out when it has a drums and a wheel cylinder is like 5 dollars,but i forgot u know everything
Dude you are very grown up aren't you..Did you not read my post i stated clearly that i owned a 95 so i was thinking it had calipers...And it's funny that i make a living working on these hunks of **** but i know nothing...LMFAO..You just need to STFU before your little *** gets banned..
