what size mass air meter will be good for 24lb injectors
Old 11-30-2008, 03:20 PM
vogs77
vogs77's Avatar
Default what size mass air meter will be good for 24lb injectors
I am getting a 24lb mass air to match my larger injectors for some upgrades, what size should I get. I have found a wide range from 80mm-55mm. I will be running a 65mm throtle body if that makes a difference. Do you think that is ok to go with a used one or just buy a new one??
thanks
mat
vogs77 is offline
Old 11-30-2008, 03:50 PM
primetime5.0
primetime5.0's Avatar
75mm would be good
primetime5.0 is offline
Old 11-30-2008, 03:53 PM
cammedlx
cammedlx's Avatar
I would go atleast with an 80mm with the supercharger and i would not buy a used one,just my 0.2.
cammedlx is offline
Old 11-30-2008, 04:08 PM
OnyxCobra
OnyxCobra's Avatar
yeah is this for your supercharged car?
OnyxCobra is offline
Old 11-30-2008, 04:52 PM
vogs77
vogs77's Avatar
Yes, for my car.
vogs77 is offline
Old 11-30-2008, 05:04 PM
OnyxCobra
OnyxCobra's Avatar
I could be wrong but you should probably be running larger than 24lb injectors on a boosted engine.
Old 11-30-2008, 07:00 PM
vogs77
vogs77's Avatar
Currently running stock engine with 19lb injectors, only 5-6 lbs of boost with FMU. Vortec kit doesnt require upgrade yet. No problems at this time, only a street car. I really dont run it that hard. Just like to spin the tires a little bit.
vogs77 is offline
Old 11-30-2008, 07:05 PM
cammedlx
cammedlx's Avatar
Stock H/C/I i assume..If so then 24's will be fine with the FMU..And i would suggest the 80mm housing just for future upgrades..
cammedlx is offline
Old 11-30-2008, 07:59 PM
NoGo95GT
NoGo95GT's Avatar
Get a Pro-M 75mm or a Summit Brand 75mm(identical to the Pro-M)., Plus it's much cheaper. A 90mm Lightning MAF would be your best bet. However, you would have to get it tuned to work properly.
NoGo95GT is offline
Old 11-30-2008, 09:42 PM
OnyxCobra
OnyxCobra's Avatar
Being boosted you should probably get a tune anyways with new injectors, I'd suggest a Lighting MAF and tune it up.
djbigskrilla
09-20-2022 01:04 AM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
dfw692
08-07-2015 11:53 PM
Quick Reply: what size mass air meter will be good for 24lb injectors
