valve springs & lifters help
12-03-2008, 01:13 AM
Im putting a comp cams 270h magnum cam in a motor and need some valve spring and lifter suggestions. So let me know what you think i should go with...
12-03-2008, 04:57 AM
12-03-2008, 06:12 PM
12-03-2008, 09:29 PM
Your cam card should make a spring recommendation. I'm a big fan of the beehive springs.
For lifters, it's hard to beat stock Ford lifters for durability. If you want a few extra rpm's, Keith Craft modifies the stock Ford lifters for that.
12-03-2008, 09:36 PM
D.R. THE PATHETIC DORK
what's the part number on the cam??? flat tappet?? or roller??
12-03-2008, 10:44 PM
Its a flat tappet. Part number is 270H.
12-03-2008, 10:55 PM
is this the falcon motor? older motor i assume.
12-03-2008, 10:59 PM
Yup its the 70 falcon motor, as i tore it down it looks like it was recently rebuilt so it all worked out good for me.
12-03-2008, 11:39 PM
so what is the problem call up comp cam and see what they say..?
12-03-2008, 11:50 PM
well im just not sure if there's a specific spring or lifter i can or cant use.
