just wanna run crank waterpump and alt pulley how do i??
Old 12-04-2008, 11:49 PM
blk89lx
blk89lx's Avatar
Default just wanna run crank waterpump and alt pulley how do i??
lookin to delete my power steering pump so all i would have left is my alternator water pump and crank. does anyone have pics of this set up or can tell me if i need to change to a foward rotation waterpump or the correct size belt i would need.
blk89lx is offline
Old 12-05-2008, 06:24 AM
86HOGT
86HOGT's Avatar
YOu can do it with just a shorter belt I believe. I seen a picture a while ago, not sure where.
86HOGT is offline
Old 12-05-2008, 11:53 AM
blk89lx
blk89lx's Avatar
anyone else?
blk89lx is offline
Old 12-05-2008, 12:45 PM
94Yellow50
94Yellow50's Avatar
wont that not work tho because of the water pump spinning a different direction than the crank?
94Yellow50 is offline
Old 12-05-2008, 12:54 PM
FORD TOUGH
FORD TOUGH's Avatar
Like this.? http://www.fordmuscle.com/archives/2...ps/index.shtmlBut it looks like the water pump will spin backwards. You may need to get a different water pump.
FORD TOUGH is offline
Old 12-05-2008, 01:00 PM
94Yellow50
94Yellow50's Avatar
forgive the lack of detail..but the red would be if you only went crank, water pump, and alt..and i would never do it because barely any belt touches the water pump...not sure but i dont think itd even work..
Attached Thumbnails just wanna run crank waterpump and alt pulley how do i??-motor.jpg
Old 12-05-2008, 01:03 PM
FORD TOUGH
FORD TOUGH's Avatar
How would you tighten it?
Old 12-05-2008, 01:07 PM
FORD TOUGH
FORD TOUGH's Avatar
I dont know if this would work? You would need a ac compressor elimnator kit or fabricate a bracket with a idler in place of the pulley I didnt label. Don't be jealous of my fancy diagram.
Old 12-05-2008, 01:14 PM
Portmaster
Portmaster's Avatar
I'm curious to see how this one plays out as I'm still trying to think of a way to run the rev rotation pump without anything but the alt. It was one of the last things on the list but you can beleive if I see a good idea, I'm taking the easy way out, lol
Portmaster is offline
Old 12-05-2008, 01:20 PM
94Yellow50
94Yellow50's Avatar
exactly my point..it wouldnt work..im sayin if he just wanted to run those three, that would be a route..and for the tightening it would take a custom touch to the alt bracket...ive seen that used as a tightener..but its still gonna be wrong if he uses that water pump
Quick Reply: just wanna run crank waterpump and alt pulley how do i??
