Cooling Problems
RE: Cooling Problems
i don't see a problem with stock gauges as long as you know your car. a gauge that jumps up/down/up/down/etc is obviously F'ed up, but if your temp gauge sits at the M in normal or at the N, it doesn't matter as long as you can stand in front of the car with the hood up and KNOW that the car aint overheating. that's my opinion.
ORIGINAL: settled4automatic
ORIGINAL: tomabram
Thats right. I have an 88 GT. Guages work just fine and the car is as old as dirt. So no reason to get ugly aftermarkets.
yeah i think i will pick up an aftermarket gauge to see what the temp. actually is. I was thinking about air in the stystem since i did replace the plug, how can i get the air out, or will it eventually work its way out?
stock heads for now and I got the stock electric fan and I believe it's a 190 thermostat
ORIGINAL: luckypballer
what thermostat do you have? Stock fan or electric? 50/50 mix? But yeah 210 is fine as long as you dont have aluminum heads
Galactic
04-29-2019 02:56 PM
