Idle Mixture on Holley Carb.
Old 12-06-2008, 09:49 AM
87Stallion
87Stallion's Avatar
Default Idle Mixture on Holley Carb.
I am trying to adjust my idle mixture on my carb. If I do it the way Holley suggest the car idles way too rich.
I adjusted it for max vacuum as per there directions but this seems to rich. Is there a better way to adjust it? Right now I have both screws about 1 1/2 turns out. Thats where it seems to run the best and not rich, however at 1 1/2 turns it isn't making max vacuum.
87Stallion is offline
Old 12-06-2008, 10:14 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I usually adjust it until I reach max vaccum then from there 1/4 turn more out and if it is still to rich look at changing the primary jets to smaller ones
mjr46 is offline
Old 12-06-2008, 11:09 AM
87Stallion
87Stallion's Avatar
Being that Im at about 3700 Ft above sea level I went from #65 primary jets down to #63.
I just changed the jets last night so I'll try adjusting it for max vacuum again and see what happens.
Old 12-06-2008, 11:44 AM
Gary H
Gary H's Avatar
Whats the idle vac. and what power valve are you using?
Gary H is offline
Old 12-06-2008, 01:01 PM
87Stallion
87Stallion's Avatar
idle vac is 14-15 Power valve is 65. Holley says a 65 is good for 14-18 inches of vacuum.
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
MacSerio
09-27-2015 01:05 PM
Quick Reply: Idle Mixture on Holley Carb.
