traction lok clutches
i was reading on 5.0 mag about rebuilding one which im doing its a piece of cake anyway, im surious they mentioned putting extra clutches in to make it tighter does anyone sell a kit with extra clutches or am i going to have to buy two kits
I wouldn't put to much stock in 5.0 magazine. Get a good set of clutches and properly install them. When you can over power it you need to step up to a better carrier.
Which month was that. I don't remember seeing an article between all the adds.lol
When I rebuilt mine I just replaced a shim on each side with two good friction discs from the old pack to have it shim|friction|shim|friction etc... instead of friction|shim|shim|friction...
This is what they meant and is pretty standard practice if you ask me.
There is a factory spec (min/max) for the thickness of the clutch pack assembly when new. Factory recommends .640 - .645 when compressed (I use a c-clamp to compress the pack, then measure with a digital caliper). If you want to increase the friction for better performance, you can set it up tighter (steels come in different thicknesses), somewhere in the .650 - .660 range. Any tighter, and you won't get the spiders back in. I don't believe additional clutches offer much of an advantage over the factory set up. Older models (80s era) arranged the clutches and steels differently than the newer models (90s era), but the set up that seems to work best is SFSSFSF-Shim (S-steel, F=friction).
