Helping a friend with a carbed H/C/I
Doesn't have to be too budget oriented, I'm sure he'll save enough money using a 302 he already has. As for the cam it was just the first one I picked, I was going to suggest a custom one for him. The AFRs don't really seem to out flow the canfield ones until the valve lift is .500 and over, if they are the same price why would they be better than the canfield ones? Just curious.
http://www.mustangandfords.com/techa...ock/index.html
perhaps you can use some info this build.
The engine will be spinning in the red to reach it.
i just traded my twisted wedges for a new set of afr 185's and they look nice and i have been talking to other people and afr and i am excited to get them bolted down on my 351
the other thing is that if your buddy is using a stock rotating assembly with the stock pistons 99.0% chance of hitting a valve , must notch pistons or use different ones
"The piston pinholes are offset (note the difference between dimensions A and B). Sherman says installing the piston “backward” with the notch facing toward the rear as shown is worth 15-30 hp, albeit at the price of increased noise when the engine is cold."
That quote was on the left side of the article with the pics. Anyone know anything about that? Does it hold true? And what kind of noise are we talking about here?
But as I understand flycutting the pistons can throw off the balance if too much material is taken out, and it also weakens the pistons.
