need help with fuel pressure
I have a D.S.S 331 with 9.25 comp., track heat heads and intake, anderson B-41 cam, 42lb injectors, aeromotive fuel pressure regulator, t-rex pump, s-trim supercharger. I currently have the fuel pressure up to about 60lbs and the plugs indicate that it is still running a little lean. Does anyone have a similar setup or know if something is wrong or about how much fuel pressure this will take? any help would be great.
RE: need help with fuel pressure
ORIGINAL: luckythirteen13
with all those mods id take the car to a dyno tuner if it was my car. better safe then sorry. plus they will get you more power out of it
mrappe
09-26-2015 10:16 AM
