AOD to T-5
Im looking to do this swap too, would like to know.
Would i have to cut the trans tunnel to let the shifter come up?
Can i use the same AOD ECM?
Will my AOD drive shaft be ok?
Can i still use my AOD crossmember?
Is the trans mount different?
Speedometer cable same?
The pedal assembly will be a pain in the *** but i figured out that part.
A t-5 of course not any newer than a 93
Bellhousing
flywheel
clutch kit
clutch cable and quadrant
pedal
and maybe a crossmember
If you plan on racing a recommend a billet steel flywheel and a blowproof bellhousing because at high rpm's you clutch or flywheel can explode and it could possibly cut your toes off.
Here is a chart that compares t-5 with the gear ratios, torque ratings, and input shaft lenghts. http://www.allfordmustangs.com/Detailed/349.shtml
Bellhousing
flywheel
clutch kit
pedal
Good Used GT T-5 Transmission
Bellhousing w/ Bolts
Clutch, Pressure Plate, Flywheel
Pressure Plate Bolts
Clutch Fork & Cover
Transmission Wiring Harness
Computer
Upper & Lower Shift Boots
Shifter & Handle
Transmission Mount
Cross member
Drive Shaft Yolk
Pedal Assembly
Clutch Cable
Clutch Fork & Cover
Computer
Shifter & Handle
Transmission Mount
Cross member
Drive Shaft Yolk
Pedal Assembly
Clutch Cable
you can use the SAME driveshaft and yoke.
this website http://www.promotionpowertrain.com/1691136.html
they have a list of parts, and sell them all.
really GREAT company to work with, and thats where ill be buying my transmission from most likely.
you do NOT need a new computer, but some computers go crazy and have issues.
so its possible that you will need a new computer, but highly unlikely.
if you plan on rebuilding your tranny, heres a good website article.
http://www.fordmuscle.com/archives/2...uild/index.php
i also ordered a DVD from this guy.
badshoeproductions.com
good luck.
good luck.
