T5 rebuild help...what bearing puller?
i'VE SEEN SOME articles tell you to get a 2x4 and set it on the ground and smack the shaft up and down allowing the jarring weight and motion to drive off some of the pressed fit pieces, I tried it once, it didn't work so well so I put it in the press
Im thinking about using a bearing separator some 2x4s and a log splitter as the press.
I have used this splitter before to press out bearings with a few quick mods to the cutting blade it becomes a very effective press and it has a nice valve so you can operate the ram very accurately and slowly
Hey
I got the all stuff I wanted to replace on the output shaft replaced and back together. (1st and 2nd gear all blockers, 1&2 slider, all bearings)
My only question right now is the 3&4 sync assemble (the shift fork engages this assy and it does not have the gear on it) When I pressed it back on there was a notch in the spines like a snap ring would go there...The manual never said anything about a snap ring (and none of the snap rings I have fit) . I pressed the 3&4 slider down so this groove was just clear of the hub (so if a snap ring did go there it could have fit)
2) this is the correct depth to press the 3&4 slider right?
1) there is no snap ring here right? or is there?
Thanks
-Gun
Thanks
-Gun
smackin the input shaft on wood works, thats what i did. one hit and it came off. shop press for the coutner shaft bearing and input shaft bearing.
when i get back later gun ill answer your question if no one else has. gotta roll out
KingRando
10-02-2015 08:06 AM
