mass air tube
it makes sense that the tube for larger injectors is smaller. the c&l maf basically tricks the computer so you can run larger injectors.
the smaller the tube is, the less air that can flow through there. the lower volume of air is measured by the computer so it then shortens the injector pulse width. the shorter pulse width is what keeps your car from running rich when running a larger injector. the larger injector flows more but because its open for less time, the two cancel each other out and afr stays stoich
It's on my site at freewebs.com
Freewebs seems to be undergoing some major changes, and attention to detail isn't what it used to be. You may get a 'security warning' or 'virus alert' when you go to this page. It seems to be a false alarm... Freewebs has assured me several times that there is NO security threat on my site. Still, I can't make any gaurantees. I'm sorry for any inconvenience, and I am working on getting the site on somewhere else.
Freewebs has proven unreliable.
Here is the link...
http://www.freewebs.com/vristang/clsampletubes.htm
I have most common tube sizes listed there. Sizes are approximate, as I have seen some variation in the C&L parts.
good luck,
jason
Here is the link...
good luck,
jason
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
