95 5.0 help
95 5.0 help
alright i have a 95 5.0 and its not getting a signal to the computer to pulsate the injectors, turn on the fuel pump, fire the plugs etc.... i have checked the pick up coil it is fine, module is fine, coil is fine, i have continuity from the 2 wires leading from the pickup to the computer.. havent checked the wires from the module as i do not know which colors to check without cutting the loom open.. can anyone get me a wiring schematic with the colors labeled or has anyone had a similar problem before??? i had a similar problem before and determined that the computer wasnt receiving a cranking signal and i believe im having the same problem but before i determined the pigtail connector to the module was bad and not making a good connection so i replaced it and have had no problem till now... i have checked it out and it is fine... i am getting power to both sides of the coil just the negative side dosent pulsate when cranking.... any help is greatly appreciated as i have no car.. sorry for the long read....
Here are some schematic's. http://www.veryuseful.com/mustang/te...#95-95Diagrams You have to spark before injector pulse. Is your distributor turning? How did you check the coil, module, and the pickup assembly. Check your grounds computer ground (I think it is near battery). It may even be a EEC power relay.
yes dizzy is turning.. i tested the coil with an ohm meter, replaced the module with a known good one also had mine tested at a local parts store, and i pulled a dizzy from another running car and tried it with no success... im pretty sure its a wiring issue as ive pretty well eliminated all other components.... i will start testing the wires from the module tomorrow also gonna pull the comnputer out and test from there also... this is pissing me off...
If you can get a known good distributor like from the car you got the module from and take that distributor and hook it up and turn it by hand to see if you have spark then. If may not hurt to try a coil off of a another car.
yea i bought a new dizzy and module... gonna check out a few wires tomorrow... havent had much time to mess with it.. if i cant figure it out im just gonna take it to a shop im already tired of messing with it... i hate wiring problems....
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
