EGR & AC DELETE ?
The only thing about the EGR is that you can't just pull the tubes off the back of the heads or you will have 2 big exhaust leaks. You need to either purchase the plugs or make your own. I have heard spark plugs fit but I used 5/8 threaded rod and cut a notch in a piece to use as a screw. The pump itself can just be removed, no need for a delete kit there. Just get a a/c delete kit and you will be set.
Thats good to know, what belt would I run if i just remove the smog pump?
Because your old belt will be longer then the new, cut it once and use it for a measure once the job is done. I've always like to take off about another 1/4" due to the old belts strectch, plus what the new belt will stretch. This should make for a good fit in my experience anyhow. Good luck
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
