EGR DELETE
EGR DELETE
I am installing Longtubes this weekend and want to get rid of all the egr crap. Whats the best way? Ive heard you can just leave the smog pump, pull all the lines off and plug the two holes in the back of each head ( which i currently have done). Will this work?? What do you guys think I should do with the egr and smog stuff? Thanks guys!
make a plate that blocks the egr, if you have stock exhaust, cork off the lines in the midpipe, you can just take the lines off the smog pump, but you can remove it and get a shorter belt and reroute and that works great also.
If you want to egr is not work just unplug the vac line. The computer will delete its function and not throw a CEL. If you want to remove it then you have to do all kinds of other stuff including a tune or an egr simulator.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
