in the middle of changnig inner tie rod ends...
Old 01-07-2009, 04:05 PM
pk222
pk222's Avatar
Default in the middle of changnig inner tie rod ends...
hey guys, I'm in the middle of changing my inner tie rod ends on my 95 mustang cobra. I've got the inner and outer tie rod ends apart but I can't find out how to get the inner tie rod end and steering shaft out. I've hears sometimes you need a special tool but I don't understand what it would do. is there a set screw or something? I don't want to force it and break something
thanks in advance
pk222 is offline
Old 01-07-2009, 04:48 PM
pk222
pk222's Avatar
anyone? sorry I'm not trying to be annoying, just trying to get it done so I won't be yelled at for taking up the whole driveway
pk222 is offline
Old 01-07-2009, 04:57 PM
aode08
aode08's Avatar
Socket adapter tool 969230 may be necessary for removal or installation. Heavy duty.
Rent it at autozone.
that end with the ball is what the tool goes on.
That shaft needs to be soaked with penetrating oil,
aode08 is offline
Old 01-07-2009, 05:08 PM
aode08
aode08's Avatar
Click image to see an enlarged viewFig. 15: The inner rod attaches to the power steering rack and pinion at this fitting; unthread it to separate the
two
aode08 is offline
Old 01-07-2009, 05:14 PM
pk222
pk222's Avatar
ok I'm goin to get the tool now and were you saying to soak the new one in penetrating oil or the old one? and for some reason when I took the boot off it leakes some fluid out, is this regular? if not what could it be? I couldn't find out what it was. It could be penetrating oil from the previous owner but I doubt they have ever been done before
pk222 is offline
Old 01-07-2009, 06:49 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you don't need a special tool!!!!!!!!!!!!!! I use a adjustable wrench on mine all the time, works great
mjr46 is offline
Old 01-07-2009, 07:10 PM
HACKGT350
HACKGT350's Avatar
leaking fluid would be power steering fluid...looks like your gunna need a new rack too
HACKGT350 is offline
Old 01-07-2009, 07:48 PM
pk222
pk222's Avatar
great... save that for another day...
I should have waited until you posted, I already went and got it after an hour and a half round trip drive... I didn't understand why I would need one but I didn't want to mess anything up but too late now.
aode08 thank you for the diagrams and pictures.
my last question is do these need to be torqued or just tight?
pk222 is offline
Old 01-07-2009, 07:52 PM
mjr46
mjr46's Avatar
I put a dab of blue loctite on the thread and tighten them ..lets say tight
mjr46 is offline
Old 01-07-2009, 08:02 PM
pk222
pk222's Avatar
ok so pft? lol
and I just noticed, one of the new tie rod ends is different and didn't come with the set screws, should I wait and get some or will it be ok?
pk222 is offline
Quick Reply: in the middle of changnig inner tie rod ends...
