excuse the newb question
but what is needed to take my motor to a 331 or 347 stroker? I have it tore down now, and I'm debating putting a stroker crank in it. Can anyone give me a quick run down of what is needed....my pistons are .060 over, .20 oversized bearings......
Also, which would be easier with those pistons bored out that far? Part numbers/links would be very helpful, I've searched but couldn't find anything.
thanks for the reply.....not to question your knowlege, but why won't a .060 over block work as a stroker? It's built solid....very fresh.....I don't plan on letting it get too hot as it's a street/strip car. I know it's easy to go out and get another block.....but I got what I got ya know? Would love to know if I can just throw a $2-300 crank in it and go with it.
I mean maybe it wouldn't be wise to spray or boost with a .060 over block, but if I can stroke it, I'll get to the power level I want N/A.....about 350 rwhp....jussst enough to give those ls1s trouble
you won't be able to just throw a crank in it and call it a stroker, you need rods, pistons, and crank and whole assembley needs to balanced, and you'll need a 28 oz damper and matching flywheel, expect to spend 1500 easily to make a stroker
You should get a block and have take it to a machine shop and have all of the necessary work done to it. You should order a whole rotating assembly because they already come balanced. http://store.summitracing.com/partde...E&autoview=sku
NOOOOOOO DONT TAKE THAT BLOCK TO THE SHOP ITS WAY CHEAPER TO BUY A NEW 302 BLOCK WITH THE 347 OR 331 STROKER KIT IN IT 2000 AND NO CORE CHARGE THAT WAY YOU HAVE YOUR OTHER BLOCK IN CASE SOMETHING EVER GOES WRONG TALK TO WOODSIE I THINK HE HAS A SIGHT ON HERE DIY LIBERATOR 347 BLOCK FROM A 302 FOR A COUPLE GRAND
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
