'95 Cobra rebuild/upgrade assistance
Top End Kits: AFR heads 165cc
Headers: bbk long tubes
Cam: comp cams maybe a xe274hr ????
Intake: edelbrock rpm2 or holley system max 2
Gears: 5 speed 3.73 auto 4.10 with a stall
Throttle Body: 70mm will do the job just incase you have more room to grow
MAF: lightning maf or a pro m or any other brand calibrated for the injectors
Brakes:????
Shocks:strange adjustables
Struts:strange adjustables
Suspension: the basics u/l control arms reinforce torque boxes sub frames
Cold Air Intake: any will do bbk etc
Short throw shifter: MGW
and a tune since your a 95'
Brakes:????
Brakes:????
Brakes:????
http://www.youtube.com/watch?v=M5EH9...eature=related
Any way to achieve this sound without taking off the vaccum hose? This is the sound I'm looking for.
Top End Kits: Trickflow TW170cc heads or AFR 185cc
Headers: BBK ceramic long tubes
Cam: one of the Comp Cams XE series
Intake:Holley Systemax II
Gears: 3.73:1
Throttle Body: 70mm professional products
MAF: stock is 70mm, if you swap top ends, consider a 90mm LMaf
Brakes: Napa pads, like previously mentioned, keep stock rotors
Shocks/Struts: Bilstein or Tokico
Suspension: Eibach Pro Kit, H&R SS
Cold Air Intake: keep your stock intake tube unless you do a top end swap
Gears: 3.73:1
11-10-2015 11:39 AM
Dan04COBRA
09-30-2015 11:46 AM
