z cam specs
z cam specs
hey guys, while using world windsor 180 heads, 1.6 rockers, and an auto with a 2800 stahl, can i install a x or a z cam in my car with the auto, or is in strickly a stick cam? im using a b cam right now, but want something more aggressive, so any advice would be helpful!!
pick a better ots cam other than an alphabet cam. btw there is already a thread up about this cam.
Intake Duration at 050 inch Lift: 228
Exhaust Duration at 050 inch Lift: 228
Duration at 050 inch Lift: 228 int./228 exh.
Advertised Intake Duration: 290
Advertised Exhaust Duration: 290
Advertised Duration: 290 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.552 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.552 in.
Valve Lift with Factory Rocker Arm Ratio: 0.552 int./0.552 exh. lift
Lobe Separation (degrees): 112
if you buy this cam you'll need to check ptv and degree it, possibly notch pistons
doesnt matter what tranny you run btw.
well right now i have a cobra intake but upgrading to a trickflow track heat, 75mm tb, 76mm mass air, 24 lb injectors, long tube headers, built aod, 4.10 gears, underdrive pulleys. a few other mods, but nothing big.
If I had to pick out an aggressive off the shelf cam for you providing you have the track heat intake Id yank a Comp Cams XE274HR for your ride. It's about as much cam as those heads can handle and would work well with your 2800 stall and 4:10 gears. It will take you to the limit of Hyd roller lifters and just about the limit of those Windsor Jr heads. Make sure you get Vavle springs to match the cam.
