Clutch noises
Old 01-11-2009, 10:18 PM
cmkp0819
cmkp0819's Avatar
Default Clutch noises
I've been hearing some things from what i think is my clutch. When it is cold, and I go to start the car up, I push in the clutch and turn the ignition. When I do this, I get a pretty loud/annoying "metal to metal" sound when i have the clutch pushed in. It stops once I release the clutch.
Also, after I start the car, there is a "squeaking" noise that I hear. If I put my foot on the clutch pedal ever so slightly, it goes away. I take it off and the noise comes back. Any ideas what this may be?
cmkp0819 is offline
Old 01-11-2009, 10:28 PM
mustangsneverdie
mustangsneverdie's Avatar
you might need a new clutch and the squeaking you hear is the throwout bearing
mustangsneverdie is offline
FORD TOUGH
FORD TOUGH's Avatar
Does it sqeak when you drive?
FORD TOUGH is offline
Old 01-11-2009, 10:33 PM
cmkp0819
cmkp0819's Avatar
Nope.
cmkp0819 is offline
Old 01-11-2009, 10:37 PM
mustangsneverdie
are you sure it doesn't squeak or you just can't hear it
Old 01-11-2009, 10:38 PM
cmkp0819
cmkp0819's Avatar
Honestly, I really don't know. My exhaust is pretty loud and maybe I just don't hear it when I drive.
cmkp0819 is offline
Old 01-11-2009, 10:57 PM
FORD TOUGH
FORD TOUGH's Avatar
Does the tranny have fluid in it?
Old 01-11-2009, 11:05 PM
cmkp0819
cmkp0819's Avatar
Not sure. Is it supposed too? Is there a way to check? Sorry for sounding so dumb, but I have zero clue about cars.
cmkp0819 is offline
Old 01-11-2009, 11:13 PM
FORD TOUGH
FORD TOUGH's Avatar
Yes it should. You will need to jack it up and support it. There will be a plug on the side of the tranny maybe 1/2 ways up (not at the bottom thats the drain). It takes a 3/8 drive ratchet. The fluid should be 1/4 from the plug. You can stick your finger in there or cut a clothes hanger and bend it to see if there is fluid. I am confused about the problem though. You said when you start it and have the clutch pushed in it makes a noise the you release it and it goes away but you said when you have it running it makes a noise and you push the clutch in the noise goes away. Am I understanding this correctly?
Old 01-11-2009, 11:15 PM
cmkp0819
cmkp0819's Avatar
When I start it, it makes a loud metal to metal type sound when the clutch is pushed in. When I let the clutch out, it makes a squeaking noise unless my foot is touching the clutch. Two totally different sounds.
cmkp0819 is offline
Quick Reply: Clutch noises
