AFR vrs Edelbrock heads
RE: AFR vrs Edelbrock heads
i got my afr's in under a week. a company in arizona had one set on the shelf and i took them
how much money do you have? the afr's are worth the weight
How would a pair of AFRs stand up to a set of decently ported edelbrocks??? The ones that i am looking at have already been ported to a "stage 3" port job... They also have a "stage 2"... So would the edelbrocks be better in this case???
go with the elderbrocks for now. if your motor isnt capable of producing the power the extra cash spent on AFRs wouldnt be worth it. go to the track or look on different sites and see what everyone is running and what times. youll see GT40 Y heads in the 10s youll also see AFRs in the 13s, youll also see GTps in the 12s and stockers inthe 11s
so it all comes down to what combo you have and how it works.
ORIGINAL: ohsoquik02
exactly
Decently ported edelbrock heads will out flow the AFR. Honestly I think AFR's are a little overrated.IMO, edelbrock flow almost as good, and with a port job they will flow the same, if not better. So I would go with the best bang for the buck. which is cheaper.
i got a set of victor jrs and rpms..i love them ...but never tryed afrs...?[&:]
first of all are the edelbrocks used or new? how much do they
want for the them -vs-the afr's ?? how much is the savings $$
Well good news everyone i found the AFR 165s within 45mins of me at central coast mustang... It was their last pair so i grabed them... thanks for all the replies...
i will post some pics later on and let you know how they feel... I am also puting cobra 1.7 rockers on also...
thanks everyone...
thanks everyone...
So how much did they want for the Eddy's? How much did the AFRs cost? Stock for stock the Eddys are just a hair shy of the flow and power numbers that the AFR 165's will make, coupled with the price savings and that's why I got the Eddys. If the guy who worked on those heads knew what he was doing (rather than some DIY fool with a die grinder) and it didn't bump the price too much higher than the AFRs then the Eddys would be the better head. But there's something to be said for getting virgin parts. You wouldn't be disappointed either way you went.
