cam size
RE: cam size
So want your car to be slow then? The #1 thing people do wrong when they build a motor is go with too big of a cam, lose a bunch of low end torque, end up having not enough vacum to run the power brakes and whole slew of other problems. Follow Vfast's advice and put in a smaller cam that has power in rpm that you use most often. I mean your car is basicly stock going to a huge lopy cam will only cause you more problems.
RE: cam size
ORIGINAL: JD1969
RE: cam size
the trickflow stage 1 is a pretty good choice. i think it makes power from idle to 5500 rpm or so. if this is a street car its likely it won't see more rpm than that. i hear its a pretty smooth idle but you can still hear it lope.
uberstang1
09-20-2015 06:42 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
