rearend swap!!!
rearend swap!!!
i have a stock '86 notch 3.8L v6 i wanted to know if the rearend off my '84 5.0 gt will interchange with my rearend?
are the 5.0 rearends posi or lsd cause i notice on my gt both wheels spin the same way when it's on jack stands does that mean anyting?
Just because both wheels spin when its on stands doesn't mean you have a trac lock (posi) rear end. Trac loc's take the load of the car moving on the ground to get it to work like you would think. If there is no load non trac loc and trac loc do the same, spin both tires.
Can you get a pic? One way to know is look at the brake line in the rear. Where does it attatch to the rear at then split? STOCK 7.5's have it at the passenger side. Unless it has been swapped that will let you know right off the bat.
Matt's 95 Stang
10-05-2015 07:16 AM
