How can I bypass the AC Compressor?
My A/C compressor locked up yesterday and munched up my serpent belt.
Wondering if anyone can tell me the best way to bypass it so I can get back on the road again. I don't want to remove the compressor, as I plan to have the AC working this summer.
Does anyone know what size belt I would need? or how to route it?
Thanks!!!!
Thanks!!!!
I don't think there would be a way to bypass it and leave it on the car. You can buy a eliminator kit which you would have to remove the compressor and put a idler in place of it from napa or carquest. Ford racing sells ac eliminator kits that move the powerstreering pump in place of the compressor. I would cap off the ac lines.
Rats! I had a feeling this was the case as I couldnt see a way to properly route the belt and still have power steering.
Would something like this be appropriate?
http://www.latemodelrestoration.com/...0%201&comp=LRS
Or should I just try to get something from one of the parts stores you mentioned?
I might PM you about that pump Sonicblue, once i figure out what my budget is for this little fiasco...
That kit bypasses your smog pump as well as deleting the a/c. You can get either the kit that moves the p/s pump to where the a/c compressor is or you can get an idler pulley and bracket that sits in place of the a/c compressor. If you get the p/s relocation kit, you'll need a shorter belt. Let me know what you decide, I'll be more than happy to work something out.
Here is what it looks like. https://www.mycarquesthomepage.com/a...rtNumber=34184
