tranny vibration
Check the pinion bearings but most likely it's the driveshaft.
What is normally ok on a 3:1 geared car is not ok on a 4.10 geared car. The driveshaft spins close to Mach 8 on a steep geared highway driven car. Balancing must be perfect.
Get to the speed you are concerned with. 2500rpm in 5th gear. Note the speed. Switch to 4rth gear. Continue at the same speed. The tach willl now read higher. It's the same rpms' as the driveshaft.
treesloth
09-28-2015 07:03 AM
