well i found me some of those afr's 185 from a guy around here he wants 500 he said they are on the car right now so he can show me that they are good, what should i look for, and if i get those heads, would a systamax intake work good with them or a tfs
well if the car runs great but if you buy the heads you need to gap check em for a flat deck. check for any dmaage. aluminum is soft and easy to wreck a head. probably want to get them milled just for good measure. probabaly lap the valves while its out. check spring pressure to make sure its still good. if you're buying them completed.
holly is a good intake if you can get a deal. but if you are buying new you'll want to know what cam you are going to use and match the intake to it
with fivepointohhhh drivin it'll be a 16 second car even with afr's, nitrous and a supercharger
with almost every post of yours I've seen you bustin on 5pointoh.wtf's up with that dude I'm gonna have to bet he knows a whole hell of a lot more than you
I'm gonna warn you, if your posts don't start to consist of substance rather than busting on another member here, then you will be removed from this section.
I'm the only poster in this section that is authorized to talk random nonsensical bull****...
I'm glad I wasn't the only person that caught that
