Suggest camshaft...
Old 06-08-2005, 07:44 PM
vfast
I ♥ Acer
vfast's Avatar
Default RE: Suggest camshaft...
do you have emissions?
vfast is offline
Old 06-08-2005, 08:06 PM
Tims 88GT
Tims 88GT's Avatar
rember its not how it sounds, its how it runs, my lunati sounds almost stock at idle but when you hit 2200 thats when my power band starts its a major diff, it pulls a lot better than stock. the thing i like the most is at the line you cant tell, then after you get going the person that was next to you is history lol
Tims 88GT is offline
Old 06-08-2005, 08:36 PM
92stang
92stang's Avatar
Not to hijack this thread but would a e-cam be ok for me all my mods are below I know I need to get a 65MM t/b and 76mm MAF fist but what do you all think?
92stang is offline
Old 06-08-2005, 08:44 PM
95_302_StangMan
95_302_StangMan's Avatar
OK. about the mods
Rebuilding to 347 Stroker
Vortex Mufflers
Smog pump skip
Catless H-pipe
Ford Racing Tranny
All AC crap gone
So with all that stuff what do you suggest?
95_302_StangMan is offline
Old 06-08-2005, 09:29 PM
vfast
I ♥ Acer
vfast's Avatar
tim......I like the quite 11 sec cars..this is what I love to build...I do not advertise what under the hood......even my S/C car looks stock
vfast is offline
Old 06-09-2005, 12:54 AM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
I agree with vfast, but I like to be sneaky. If you guys go with some huge cam based upon the sound, you will lose a ton of low end torque, lose vacume (this affects your power brakes) and the car will generally suck to drive.Oh yea and if you don't have enough supporting mods the car will actually be slower.(I love to race over cammed cars, I make them look silly). The e-cam will work nice if you plan on upgrading things like the intake/heads/exhaust somtime down the road, but remember you won't get the full power of it untill all the other mods are done. Personally I would keep your stock cam untill you do a head swap, the guys running NMRA Factory Stock are limited to a stock 5.0 cam and they run in the mid-high 11's.
JD1969 is offline
Old 06-09-2005, 03:00 AM
Eric @ DMS
Eric @ DMS's Avatar
As was mentioned, bigger cams aren't necessarily better. It's how your HP/TQ curves look. It's the whole package (cam and supporting mods) that make a difference.
Eric @ DMS is offline
Old 06-09-2005, 12:20 PM
JD1969
JD1969's Avatar
ORIGINAL: 95_302_StangMan
OK. about the mods
Vortex Mufflers
Smog pump skip
Catless H-pipe
Ford Racing Tranny
All AC crap gone
Be more specific, what intake,what heads,what gear do want to run?
JD1969 is offline
Old 06-10-2005, 02:03 PM
95_302_StangMan
Ok I think if i get a new intake it will be a trick flow intake, i will probley get some gt-40 heads, this might be a dumb question but what do you mean by what gear do you want to run?
Old 06-10-2005, 05:27 PM
JD1969
JD1969's Avatar
The more info we have the better the suggesttion will be. As for gears I asked because if you tell me that you want to run a 3.73 gear then the cam I suggest would be smaller, if you said 4.10 then we could look at a different cam yet again. I think you will be happy with a cam around the 218/222 duration @.50 and in the area of .530 lift, stay around a 113-115 lsa, and you will get alittle lope but nothing too bad. When get ready to actually buy the cam, call the cam company's tech line and talk to them about what cam they reccomend, they are usually pretty close, but they do tend to er on the small side because everybody wants a cam thats too big.
JD1969 is offline
Quick Reply: Suggest camshaft...
