head swap? Should I attempt to do it myself?
Old 06-08-2005, 07:27 PM
sick95gt
sick95gt's Avatar
Default RE: head swap? Should I attempt to do it myself?
I want to do a cam, but people are saying that I have to pull the motor to do it. Or take apart the whole front end to pull the cam out.
sick95gt is offline
Old 06-08-2005, 07:32 PM
sick95gt
sick95gt's Avatar
and if I do a cam, how agressive should I go? I don't want it to lobe like crazy, but I do want the power gains over the e303 I have now. Someone said an x303, but don't know if I'll have to mod other things for clearance. Someone said I would have to notch the pistons.
sick95gt is offline
Old 06-08-2005, 07:43 PM
vfast
I ♥ Acer
vfast's Avatar
well I would get a small daul pattern cam to get more lift on the exhaust..or you can just add some 1.7 rocker that will put you near .472 lift..a nice small increase
vfast is offline
Old 06-08-2005, 07:46 PM
sick95gt
sick95gt's Avatar
I got 1.6 because someone with the same heads said they barely cleared with 1.6. D*mn it! Do you really think 1.7's will work without clearance probs?
sick95gt is offline
Old 06-08-2005, 07:49 PM
vfast
I ♥ Acer
vfast's Avatar
you'll have some issues with the valve cover....just a lil grinding with a Dremel take care of that...yeah I have some 1.72's on mine
vfast is offline
Old 06-08-2005, 07:51 PM
sick95gt
sick95gt's Avatar
do you think it's worth doing? I can still return and exchange them to Summit for 1.7's.
sick95gt is offline
Old 06-08-2005, 07:59 PM
vfast
I ♥ Acer
vfast's Avatar
I would every lil bit helps and it's no more work to do it
vfast is offline
Old 06-08-2005, 08:08 PM
sick95gt
sick95gt's Avatar
thanks. I think I might just exchange them. I might even attempt to do the install with the help of a few others. Any other pointers or things to watch out for??
sick95gt is offline
Old 06-08-2005, 08:22 PM
Quik
Quik's Avatar
your lift with the 1.72s will be like .533 since they are about .35 added to the lift E cam is .498 so add .35
if you think you can then go ahead, reason i stated my last reply is its basic tear down knowledge but you do need to know some things when it comes to putting it back together.
if you get scared just ask
Quik is offline
Old 06-08-2005, 08:32 PM
sick95gt
sick95gt's Avatar
Oh, I'm hella scared-mostly about putting it back together and making sure it seals right and stuff. I can tear it down no prob, but I'm in the lack of knowing exactly how to do the pushrods and the rr.
sick95gt is offline
Quick Reply: head swap? Should I attempt to do it myself?
