Fuel Pump , Not getting power?
I just put a new fuel pump installed thinking it needed one>? ,
And guess what it still deosn't work so my best guess is no power to it ?
Where is the fuse and what fuse controlls the fuel pump? , and if there is a relay where is it located specificly thanks!
You need to check that you have power making it to the pump. Check that you get power at the relay when the key is bumped, if you have power there then you need to move to the inertia switch, power coming in and out of the switch. If you have power at both locations then the issue is between the switch and the pump.
Here are diagrams of the locations, you will need to look up the wiring diagrams in your book.
http://i43.photobucket.com/albums/e4...ms/inertia.gif
http://i43.photobucket.com/albums/e4...rams/relay.gif
+1 on the relay. do you have a multimeter? check the relay with your multimeter to see if its working. do you hear your fuel pump turn on when you turn your key? if the relay is working go to your fuel pump and use your multimeter for continuity. Thats what I would do. Good luck hope ya get that fixed... no stang = poooop
uberstang1
09-20-2015 06:42 PM
