gas gauge problems
Old 06-08-2005, 06:53 PM
Fubar 5.0
Fubar 5.0's Avatar
Default gas gauge problems
i have a 87 5.0 and the gas gauge is pinned at full and stays there. i dropped the tank and pulled the plug off the sending unit and theres power there. i grounded each wire and that did nothing then i connected both wires and that did nothing. my only idea is that the hot wire is gronded somwhere maybe. thanks for any help
Fubar 5.0 is offline
Old 06-08-2005, 07:12 PM
Fubar 5.0
Fubar 5.0's Avatar
Default RE: gas gauge problems
Also is there any way to test it?
Old 06-09-2005, 12:27 AM
stanglx2002
stanglx2002's Avatar
the sending unit needs to be replaced its a common problem
stanglx2002 is offline
Old 06-09-2005, 11:45 AM
73Cleveland
73Cleveland's Avatar
With the plug from the sending unit removed & without you grounding it, does the guage read full or empty?
If it reads full while unpluged without you grounding it, it's most likely a short in the wires.
If it reads empty & then goes to full when you do ground it, it's the sending unit.
73Cleveland is offline
Old 06-09-2005, 05:24 PM
Fubar 5.0
Fubar 5.0's Avatar
it reads full when unplugged so im thinking its a wiring problem
algregory
09-11-2015 11:44 AM
Pyrate Dave
09-10-2015 07:30 PM
zachary1988
09-04-2015 03:04 PM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: gas gauge problems
