bypass heater?
bypass heater?
I was wondering if I could bypass my heater core until I get it fixed. The person that I bought the car from said that the core was replaced about a year or so ago but when I go to defrost my window (when it's raining) I can smell the anitfreeze for a little while. I know that in older cars you could do that an not worry about it but now a days with cars and computers I don't know if it will freak the computer out. By the way it's an 88 lx 50.
RE: bypass heater?
Thanks. Just wanted to make sure that I could do it with out sending the computer to the crazy house. Now, to change out the heater core you have to take the dash down, right? I had ford do it for me and they only charged me about 250 to get it done. I don't think that's to bad of a deal.
RE: bypass heater?
Bypassing the heater core will definitely help cool down the interior in the summer. Even with the heater control valve off, hot water migrates into the core - eventually it will get up as high as 150*f and all those BTUs have to radiate into the passenger compt. If you have AC, you'll notice a big difference in the outlet temps, especially after a 15 minute shut down. All 8 of our vehicles get the heater core bypassed about this time every year. On my wife's supercharged Grand Prix, I installed a pair of 3/4" diverter valves (the hose connections at the core are impossible to see....) and ran two foam insulated heater hoses out in front of the radiator where I mounted a heater core from an Isuzu Trooper to help cool the engine. It adds about a half gallon of moving coolant and keeps the temp gage at about 160-190 where it used to climb up around 230 after spooling the charger up between traffic lights. Cost to install is less than $40 which is cheap considering the payback. I haven't done it yet, but on the 5.0, adding an aux core would really help get the coolant temp lowered, esp with a small 12v fan to get the air moving when the car is at idle or stuck in summer traffic and the temp gage starts creeping up.
RE: bypass heater?
My stang hasn't had any problems with the temp. but I don't like to smell the Antifreeze when I turn on the vent when it's raining. I didn't think about using a diverter valves that would make it easy to make everything work when I want to and then when I don't. Thanks....
Seanam
10-04-2015 10:15 AM
